In order to connect your Lutron devices to your Hubitat Elevation network you will need a Lutron Smart Bridge Pro, RA2 Select Main Repeater or RA2 Main Repeater. Follow Lutron’s instructions to connect your devices to the Smart Bridge Pro, RA2 Select or RA2 Main Repeater, then follow these steps to connect your Smart Bridge Pro, RA2 Select or RA2 Main Repeater to your Hubitat Elevation Hub:
From the sidebar of your hub, select Apps and press the Add Built-In App button.
Choose Lutron Integrator from the list of Hubitat Elevation Built-In Apps
You will be required to enter information from your Lutron Smart Bridge Pro or Main Repeater during the creation of a new Lutron integration on your hub. All the necessary information can be found in an integration report generated by Lutron software. For Caséta or RA2 Select, this can be done in the Lutron mobile app:
Open the Lutron app on your mobile device and tap the gear icon at the top left to open Settings.
Tap Advanced to access the Advanced Settings.
Tap Integration.
Ensure that Telnet Support is enabled.
Tap Network Settings and write down the IP address of your Lutron Smart Bridge Pro, then tap < Integration at the top left to navigate back.
Tap Send Integration Report.
This is where you will find the names and Lutron Integration ID numbers for each of your attached Lutron devices. Selecting this option will create a draft email on your mobile device which you can email to yourself. If you only have a few devices, you can simply make note of their device names and Lutron Integration ID numbers, and then close the draft email without sending.
Open the Lutron Integrator app.
Select Create New Caseta/RA2 Integration
Name your Lutron integration and enter the IP address of your Lutron Smart Bridge Pro.
Next you will need to select all of the Lutron devices you want to connect with your Hubitat Elevation. If you only have a handful of devices, it is easiest to just select the Select Lutron Devices button.
If you have dozens of devices (or simply prefer this method), it may be quicker to toggle on the Use configuration list instead of interactive setup option.
NOTE: If you have already setup your Lutron Integrator app using either the interactive device entry method, when you select Use configuration list instead of interactive setup, the Lutron Integrator app will automatically convert from the previous setup to the new configuration list. Once this has been done, you may not go back to the interactive method.
To add devices using the configuration list method:
Enter your devices in a list with each device on its own line in this format: devicecode,id,name (see below for an explanation of device codes).
When you are finished adding devices, select Done.
Whether you use the interactive or configuration list method to add devices to Hubitat, you will need to specify the Lutron device type when adding the device to Hubitat. For the most part, choosing the correct device type should be straightforward (e.g., a Lutron shade is a shade, and a thermostat is a thermostat). Certain device types deserve special notes:
pushed, held, and doubleTapped events from the Pico remotepushed and released events from the Pico remote (the pushed event will occur immediately on physical button press rather than release, as there is no need to wait to figure out if the event is a push or hold; you may notice the driver used for this device is called "Lutron Fast Pico" for this reason).You will now be able to use your connected Lutron devices in Button Controller, Rule Machine,and other apps.
When you add new Lutron devices, you will need to first add them to the Lutron Smart Bridge Pro via the Lutron app, then return to the Lutron Integrator app to add the devices to your Hubitat Elevation hub using one of the methods above.
If using Essentials or Inclusive software version 12.2.1 or later, you must set the telnet credentials for the Main Repeater to be: username: lutron, password: integration manually.
