Visual Rules Builder allows you to create simple or somewhat complex rules — actions to run in response to one or more trigger events, optionally with some condition to prevent triggering in certain cases.
From the sidebar of your hub, navigate to Automations and select Add Automation or Add Built-In Automation:
Choose Visual Rules Builder from the list of built-in automation apps.
Navigate to Apps and select Visual Rules Builder (install using the steps above if you have not already).
Select Build New Visual Rule.
Create a name for your rule in the Rule name box. (This is how the rule will appear in your Apps list, in Logs, and in other places. A descriptive name like "Front Porch Light Off in AM" may be helpful.)
Then, follow the prompts to create the rule. For example:
Tips:
Be sure to select Save or Save and close after creating or editing your rule.
Visual Rule Builder is somewhat similar to Basic Rule, although the interface is different.
On the other hand, Rule Machine is the most powerful option, although it is more difficult to learn for many new users. We suggest starting with another option (depending on your preferences) and moving to Rule Machine if you discover a feature you need that is not offered by other apps.
Finally, note that there is also no reason to pick only one!
