The Settings > Matter Details page shows you details about the Matter Fabric (collection of Matter devices) on your Hubitat Elevation hub.
Matter support is not available on hub models prior to model C-5, and this page will not appear on those hubs.
This page offers an advanced view of details about your Matter Fabric and Matter devices. It may be useful for troubleshooting; however, most users will not routinely need to use this page. For example, to add a Matter device to your hub, use the Add Device page.
You will see either an Enable or Disable button towards the top of this page (the Disable button is the configuration pictured above).
Enable: Enables Matter on this hub by either:
Disable: Disables Matter on this hub. Most of the below will be unavailable when disabled.
Finally, a table of all Matter devices on your Hubitat Elevation Fabric will be listed. Details for each device include:
Not all information may be available for all devices; the Unique ID, Manufacturer, and Model columns may be blank if the device did not respond with this information within the allotted time during pairing. This does not indicate a problem by itself.
