The built-in AI (MCP) Connector Integration app allows compatible local AI assistants to access your Hubitat hub,
The app UI will provide the information you need to connect to local AI agents (cloud agents are not supported at this time, but note that only the agent needs to be accessible locally), including the local MCP server URL and configuration examples for common AI agents.
Part of this configuration includes a bearer token, which should be protected like a password, as it provides access to your hub. If you believe this has been compromised, use the reset authorization token link at the top of the app to generate a new token, which will require updating the configuration in your agent with the new data.
