The LIFX Integration allows you to import LIFX devices, including light bulbs and lightstrips, into Hubitat Elevation. The devices must first be configured (added to your Wi-Fi network) in the LIFX mobile app. They can then be added to Hubitat Elevation.
Navigate to Integrations > LIFX Integration (if not listed, install first using the instructions above).
To add a new LIFX device, select the device(s) under LIFX Device to Add under the Add LIFX Devices section.
To view LIFX devices that have already been added to your system, look under the Installed LIFX Devices heading. Alternatively, you may navigate to Devices (on the left) to see all your Hubitat Elevation devices and find your LIFX devices in this list.
Preferences for individual LIFX devices can be set on the device detail page for the particular device. Polling is disabled by default but must be configured on any particular device to capture changes made outside Hubitat (e.g., from the LIFX app or other integrations made directly to LIFX). This is not necessary to configure if you only make changes from Hubitat or do not rely on the state of the device on your hub reflecting such changes.
