The built-in Tuya Integration app allows you to add compatible Tuya devices to your hub. This integration requires hub model C-8 Pro.
- From the sidebar of your hub, navigate to Integrations and select Add Integration or Add Built-In Integration:
- Select Tuya Integration from the list of built-in apps.
- You will likely see Integration is NOT running at the top of the app page with an enable link beside it. If so, select enable, wait a few minutes, and proceed when the text changes to Integration is running.
- When you see Integration is running, you can proceed with following the prompts in the app to finish configuring the app and add devices.
Please note that this integration is currently in beta. If you continue to have problems, please visit https://community.hubitat.com for discussion.
Follow the prompts in the app to set up the Tuya integration. A Tuya "cloud project" is required for initial setup and device discovery. However, regular device control will be done locally after this initial setup.
