Hubitat Elevation is a Z-Wave® Plus central static controller which may be included in any Z-Wave network to operate Z-Wave certified devices from other manufacturers in your home.
This document is intended to convey standard Z-Wave operations available on the hub as is necessary for any certified Z-Wave controller. If you are a user looking to troubleshoot a Z-Wave problem on your hub, we suggest other documentation, such as How to Troubleshoot Z-Wave.
The information in this document is applicable to hub models C-7 and newer only.
The Z-Wave protocol is a low powered wireless interoperable RF communications technology designed specifically for control, monitoring and status of residential and light commercial Internet of Things (IoT) devices. It supports full mesh networking and may be used with or without a coordinator node (hub). Z-Wave operates in the sub-1 GHz band and is impervious to interference from Wi-Fi and other wireless technologies in the 2.4 GHz range such as Bluetooth® and Zigbee. For a more information about Z-Wave technology, please visit z-wave.com.
Regardless of vendor, all mains-powered nodes within the network will act as repeaters to increase range and reliability of the network as a whole. These non-battery-operated devices are called repeaters or sometimes "routers." Battery-powered Z-Wave devices do not repeat signals and are referred to as end devices.
The Hubitat Elevation hub supports Z-Wave S2 security. When a security-enabled Z-Wave device is added to the Hubitat Elevation network, its communication will utilize 128-bit AES secure encryption.
Prior to adding devices to the Z-Wave network of your hub, it is required that you first exclude the device from any previous networks it has joined. This may be accomplished by performing a Z-Wave Exclude to remove the device from the Z-Wave network of the controller it formerly joined. However, it is not required that you perform this step using the previous controller. If the previous controller is unavailable or it is not convenient to perform Z-Wave Exclusion using the former controller, a General Exclusion may be performed from the Hubitat Elevation hub.
Navigate to the Devices page from the hub home page, then select Add Device:
Navigate to Settings > Z-Wave Details.
Select Z-Wave Exclude (under Maintenance). Hubitat Elevation will enter Z-Wave Exclude mode for 30 seconds.
Place your device into Z-Wave exclusion mode. The device manual should document this procedure for your particular device (often pressing or holding a button and often the same as inclusion). If the device manual is not available, Hubitat also has instructions for many compatible devices on the Compatible Devices List under the "Instructions" column.
Upon successful exclusion, the Hubitat Elevation hub will display the message "Unknown Z-Wave device successfully excluded" (or the name of the device if it was added to this hub; in that case, it is preferable to remove the device from its device detail page instead).
Alternatively, a general Z-Wave exclusion can be performed from Devices > Add Device > Start Z-Wave Inclusion (which may be convenient if you are about to add a Z-Wave device and want to make sure it is excluded — and ready to be included — first).
Select the Devices menu item from the sidebar, then select Add Devices in the upper right:
Select Z-Wave under Add Device Manually, or use the Find by device type (to see compatible devices sorted by type, like dimmer or motion sensor) or Find by brand (to see compatible devices sorted by manufacturer/brand) options, then continue following the prompts to find your specific compatible device.
Put your device in paring mode (if not virtual), according to the device-specific instructions presented in step 2 or the ones included with your device, and follow the prompts.
Non-secure Z-Wave devices will pair without any additional action required. Devices that support Z-Wave S2 security will prompt as described below. (Devices that support security but only the older S0 security will also not prompt, and they may pair either securely or not, depending on what the device requests. It is recommended to avoid S0-only whenever possible.)
For Z-Wave devices that support S2, you will see a security popup shortly after pairing begins asking if you want to pair with or without security. Choose your desired option:
If you choose to continue with security, you will be prompted to either enter part of the device-specific key (DSK) or confirm that the code you see matches the device, depending on the type of S2 used. This code can usually be found on a sticker on the device or in the packaging.
Using the Hubitat Elevation mobile app, navigate to the Devices tab, select the + (plus) icon on the toolbar, then select Add SmartStart Devices.
Select the SmartStart button.
Tap the QR code icon to use your device camera to scan the QR code of the SmartStart compatible device.
Scan the device QR code.
Pull the battery tab, or remove and replace the device battery to initiate automatic joining to the Hubitat Elevation hub. Within 10 minutes, the device will be automatically added to the hub.
If you are unable to scan the QR code, the Device Security Key (DSK) may be manually input by tapping on the pencil icon.
You must enter the entire Device Security Key (DSK) and select which security keys to use.
Continue adding additional S2 SmartStart devices. Each device’s unique Device Security Key (DSK) will be stored in the hub, but will not be included in the Z-Wave network until they are powered on. The Hubitat Elevation app will indicate the device status in the Z-Wave network. • Pending - The node will be added when it issues SmartStart Inclusion requests. • Passive - The node is unlikely to issue SmartStart Inclusion requests. • Ignored - SmartStart Inclusion requests are ignored unless changed by controller. The device DSK is cross-referenced against the provisioning list and the device is included if authenticated. Within 10 minutes, the device will be automatically added to the hub.
Using the Hubitat Elevation mobile app, navigate to Tools and press the Z-Wave Tools card.
Tap the SmartStart button.
Tap the trash can icon to remove a device from the provisioning list. Removing an item from the SmartStart provisioning list does not remove it from the hub. You must also follow the manufacturer instructions to manually exclude the device or factory reset it, so it will no longer be part of the Z-Wave network. Keeping devices in the provisioning list allows them to be factory reset or excluded, and they will automatically be included in the Z-Wave network again, as long as they have power.
Z-Wave SmartStart simplifies and significantly reduces setup time by allowing out of the box device installation, without the need for an instruction manual or complicated button and power-on sequences. With a quick scan of a QR code, SmartStart is designed to facilitate the inclusion of multiple devices simultaneously by storing unique Device Security Keys (DSK) in the hub. This ensures that the Hubitat Elevation hub is ready for error-free, and uniform inclusion across all device types and brands with secure S2 security framework, before the device is even powered on for the first time.
For added convenience, the order in which the devices are powered is irrelevant and Hubitat Elevation will include them as long as they are on the provisioning list and powered on. This also enables devices that are on the provisioning list to be factory reset or removed with classic exclusion, and they will automatically be included in the Z-Wave network again as long as they have power.
Continue adding additional S2 SmartStart devices. Each device’s unique Device Security Key (DSK) will be stored in the hub, but will not be included in the Z-Wave network until they are powered on. The Hubitat Elevation app will indicate the device status in the Z-Wave network. The device DSK is cross-referenced against the provisioning list and the device is included if authenticated. Within 10 minutes, the device will be automatically added to the hub.
Tap the trash can icon to remove a device from the provisioning list. Removing an item from the SmartStart provisioning list does not remove it from the hub. You must also follow the manufacturer instructions to manually exclude the device or factory reset it, so it will no longer be part of the Z-Wave network. Keeping devices in the provisioning list allows them to be factory reset or excluded, and they will automatically be included in the Z-Wave network again as long as they have power.
Select Z-Wave under Add Device Manually (it is not recommended to use the "Find by..." menus in this case, as these devices are unlikely to be listed in these options).
Select Start Z-Wave Inclusion.
Enable Learn Mode on the hub/controller that will be the Z-Wave secondary controller. If successfully included, the device should appear like a "regular" new Z-Wave device on Hubitat Elevation, and network information from the Hubitat Elevation hub will be replicated on the secondary controller.
Each Z-Wave device builds a neighbor table to keep track of which router devices are its closest neighbors. When you initiate the Z-Wave Repair function, you are instructing each Z-Wave device on the network to re-establish which routing devices are its closest neighbors, and therefore the most efficient route back to the hub. This also tells each device to forget about router devices that no longer exist on the Z-Wave network, or are now out of range and no longer able to be used for routing.
Start by enabling Z-Wave Inclusion mode on the Z-Wave Plus S2 primary controller, so devices may be added its network.
Tap the Learn Mode button, then Start Learn Mode.
NOTE: If the hub has any nodes joined to it, then it cannot receive network information from the primary controller. To allow the hub to join as a secondary controller, you must first exclude all joined Z-Wave devices.
Leave all security modes enabled on the primary Z-Wave Plus S2 controller.
The primary controller will prompt the user for the first segment of the DSK (Device Specific Key) from the Hubitat Elevation mobile app.
Enter the first 5 digit segment shown in the mobile app, into the primary controllers user interface when prompted.
When successfully added, network information from the primary controller will be replicated on the Hubitat Elevation hub.
Start by enabling Z-Wave Inclusion to add devices to the network of the Z-Wave primary controller.
The primary controller should indicate a device has joined its Z-Wave network.
If a device becomes unresponsive or is no longer available, the Hubitat Elevation hub has advanced user functions to Replace, or Remove the failed node.
Any node the Hubitat Elevation hub cannot reach using routing and explorer frames is considered to be failed or non-responsive. Sleeping node types such as motion and contact sensors can be considered as failing after missing more than 2 consecutive Wake Up periods. Users may choose to remove the failed node. NOTE: Removing the device from its device details page (using the "Remove" button at the bottom) is preferred over this method; see instructions on the Device Detail page documentation for more.
Navigate to Settings, then select Z-Wave Details.
Select the Remove button, if available, in the row corresponding to the desired node.
A node that has an entry in the hub database, but is non-responsive may be Force Removed from the Hubitat Web Interface Device Detail page. However, if a device is Force Removed, it will leave a node entry in the Hubitat Elevation Z-Wave Radio Devices list. Check for and manually remove the "ghost" entry, if present, by following steps 1-2 above (it will helpful to note the node ID before removing the device).
If a Z-Wave device node entry remains, but there is no matching database entry, a Discover button will appear in the Z-Wave Details table to allow the device to be (re)added the hub database.
From the Z-Wave Region drop-down menu, select your country, then select the Update button.
Select Settings (in the sidebar on the left), then select Shut Down. It is not adequate to simply reboot the hub, since the Z-Wave radio is not powered down during a reboot. You must shut down for Z-Wave region changes to take effect.
After the LED on the front of the hub turns red, unplug the hub from wall power, wait at least 30 seconds, then reconnect to power and wait for the hub to reboot.
The Z-Wave radio may be enabled or disabled by selecting the desired state from the drop-down menu. This may be useful if you have a Z-Wave device that has become unresponsive, but does not have a FAILED status. You can set the Z-Wave status to Disabled, select the Update button, then change back to Enabled, and again select the Update button, rather than shutting the hub down to power off the Z-Wave radio.
WARNING! Resetting the Z-Wave radio to factory default will remove all devices from the Z-Wave radio database and the corresponding nodes from the Z-Wave Details table (though the Hubitat devices will remain in Devices — no longer usable but possibly useful for reference). All Z-Wave devices will need to be re-included in order to function again. This will entail setting up each device as if it were a new device, including rebuilding all apps/rules that used the device. PROCEED WITH CAUTION.
Note that the above procedure affects only the Z-Wave radio; other hub contents remain unaffected.
