Elevating your smart home with Hubitat Elevation means you can do so much more than just control devices from a smart phone or tablet. That's why we built Hubitat Elevation to be both accessible and configurable from a web browser on your phone, tablet or computer, giving you the freedom to choose the most convenient method.
Pressing on the icons in the side bar will quickly move you between pages of the hub.
Use the built-in search function.
Press the Hubitat Elevation logo to return to the Main Menu page.
Change the view type and sorting order to suit your preferences.
Know how to disable devices or apps you suspect are causing issues.
As you add devices, the list can grow quickly. The simplest way is to use the search function built into Hubitat Elevation, but if you're already further down a long device list, getting back to the search bar can take some time.
Another way to quickly move to devices is to type the first letter of the device name.
Since Hubitat Elevation is web-based, using your web browser's forward and back arrows can be a fast way to navigate.
Most changes within the hub user interface will update dynamically, while other changes may require you to press somewhere in the background or press an update button. However, if you're using the previously described method to move forward and backward in the browser, it's a good idea to refresh the page in order to ensure you have the most up-to-date information in front of you.
Having multiple tabs open is convenient when you're troubleshooting. For example, you might have a problem device's details open in one tab and logs open in the other tab.
