timeToday()
method is now available in Drivers as well as Apps
- New method available in Drivers and Apps:
GPathResult parseXML(String stringToParse)
¶ New Drivers and Devices
- Rule Machine:
- mode input in apps:
- if
multiple: false
is selected (also the default), previously the platform would return an array with the selected mode as its single element (a bug). That bug has been fixed, which means that any app using this input will need to be updated accordingly. This would primarily affect a test against the mode input setting, where previously it would be something like: location.mode in myModeInput
- Now that same test would be:location.mode == myModeInput
- Hubitat Dashboard
