- Z-Wave device join improvements
¶ Drivers and Devices
- New drivers:
- keyWe lock using keyWe Z-Wave Lock
- August Pro Z-Wave Lock using August Pro Z-Wave Lock
- New devices:
- Schlage FE599 using Generic Z-Wave Lock
- MCOHome z-wave dimmer switch using Generic Z-Wave Smart Dimmer
- Leak Intel leakgopher valve using Generic Z-Wave Valve
- New driver features:
- Chromecast:
- add queue for TTS messages (prevents truncation)
- add stop after TTS preference setting
- OpenWeatherMap:
- Allow scheduling of refresh
- Add option to specify coordinates
- Zone Motion Controllers: fixed null error on first false motion activation.
- Chromecast: fixed mute and volume state inconsistencies.
- Properly parses Z-Wave AssociationGroupNameReport.
- Properly parses Z-Wave Crc16Encap.
- Rule Machine:
- Fixed Before sunset and sunrise offsets. Note: Any rule with an offset before sunrise or sunset should be opened and Done hit to reschedule.
- Fixed cancel on truth change.
- Motion Lighting:
- Fixed Don't Turn Off if Already On.
- Fixed delay per mode.
- Thermostat Scheduler:
- Fixed modes setting setpoints and initialization.
- Fixed manual hold sequence.
- Fixed hold-off restoration sequence.
