- ZigBee stack stability improvements
- Add Z-Wave PowerLevel V1 command classes
¶ Drivers and Devices
- New drivers:
- Leviton VRSC4
- Qubino 1D Relay Module
- New driver features:
- Chromecast devices: Add playTrack command
- Requires custom command in RM
- Supported media mp3, mp4
- Yeelight integration: Now supports Lightstrip Plus
- ZWave ConfigurationSet command now handles size parameter properly.
- SharpTools: Fixed issues where some events aren't reporting.
- Rule Machine:
- Fixed bug for missing UI for Repeat N Times.
- Fixed bug for player commands for false.
- Fixed missing level for setting color, now ignores missing level.
- Fixed global variable as trigger events.
- Mode Manager:
- Fixed bug with presence sensor return from Away not honoring modes to Not change from.
- Fixed ui bug with sunrise/sunset offsets.
- Motion Lighting:
- Fixed missing option for adjust on mode change.
- Fixed using color with no modes.
- Zooz Motion Sensor ZSE18: Fixed errors on configuration reporting update.
- Z-Wave battery reporting updates: Updated for device going offline.
- Samsung Button: Added missing refresh command.
- Generic Z-Wave Glass Break: Fixed configuration error.
- Simple Lighting: Fixed delayed off/on for switch on/off.
- Iris V2 keypads: Fixed keypad leds remaining on after initial join.
- Past Logs on Model C-5 now shows logs in local time.
- Installed Apps List search is now case insensitive
- Fixed 404 error if child app is removed coming from App Status Page
