- Deprecated
com.hubitat.zigbee.DataType. If you are using this class in your drivers, be sure to import hubitat.zigbee.zcl.DataType. The deprecated class will be removed in a future release.
- Changed “User Administration” section in settings to “Hub Login Security”
¶ Drivers and Devices
- New drivers:
- Qubino Thermostat Module (ZMNHID3)
- Qubino 1 Relay Module (ZMNHAD3)
- Dome Range Extender (DMEX1)
- Iris Keypad V2
- Iris Keypad V3
- AduroSmart ERIA Dimmer Switch
- AduroSmart ERIA Contact Sensor
- AduroSmart ERIA Motion Sensor
- Sylvania Lightify Smart Switch
- Aeotec Nano Switch
- New device support:
- Aeotec Range Extender 6 (using Generic Z-Wave Repeater)
- New driver features:
- SmartThings Presence Sensor V2 and V4:
- Implement Tone capability (beep)
- Add 10 and 15 minute presence timeout options
- All keypad drivers: Implement Tone capability (beep)
- Chromecast drivers: Clear TTS Q when driver is initialized
- Notifications: Set up notifications from device events, lock codes, and mode changes.
- Rule Machine: New Conditions/Trigger Event definition UI, and new Rule definition UI
- Dashboard v2.0: read more at community.hubitat.com regarding all the changes and additions to Dashboard
- Qubino 1D Relay Module: Fixed reversed NC/NO options for Input 2 Contact Type option.
- Sylvania Dimmer Switch Button Controller: Fixed erroneous button events.
- Scene-1.2: Change child device names when Scene name is changed.
- Group-2.0: Fix zigbee group hue and saturation not working
- SmartThings Presence Sensor V2 and V4: fix battery reporting
- Iris V3 keypad: Fix audio alerts not working correctly
- Iris V2 keypad: Fix panel lights remaining on
- Hubitat Safety Monitor:
- Fix cancel arm not disarming keypads
- Fix chained arming of multiple keypads when HSM armed from a keypad
- Generic Z-Wave lock: fix decrypt error on Kwikset when using LCM to manage codes.
- Chromecast drivers: Increase delay time of “Stop after TTS is complete” preference option by 50%
- Aeon Multisensor 6: Fix configuration preferences not honored
- Hue integration: Fix color commands failing when attribute values are passed as strings
- Sonos integration: Implement missing volumeUp and volumeDown commands
- Zooz Power Strip: Fixed configuration parameters that don't work with firmware 2.0
- New User Getting Started fix for not exiting properly after entering postal code
