¶ Drivers and Devices*
- New drivers:
- Sengled Element Classic with motion (E13-N11)
- GE Zigbee Switch (45856GE)
- New tested devices:
- Sengled Smart Plug (E1C-NB6) using Generic Zigbee Outlet
- Sengled Multicolor Light Strip (E1G-G8E) using Sengled Element Color Plus
- Sinope Thermostat 3KW (TH1123ZB) using Sinope TH1124ZB (4KW) Thermostat
- Zemismart Zigbee Switch (ZM-01-DK) using Nue Zigbee Switch
- New driver features:
- Power reporting preference added to GE Zigbee Dimmer and Switch drivers
- Duplicate event suppression preference added to Zooz 4-in-1 Sensor
- Group 2.1 introduced. Existing Group 2.0 instances will continue to function properly, and do not need to be converted to Group 2.1.
- Offers improved speed for UI and group activation.
- Supports option to have group device indicate if any member device is off.
- Supports option to have group device show the level of member devices set by other means.
- Maker API:
- Now supports multiple device command parameters, separated by commas. Command parameters may be integer or decimal numbers, or strings.
- Now supports sending device events as JSON object in POST to specified URL, and provides endpoint to set that URL. See this post.
- Mode Manager: Now allows Later of Two Times option.
- Rule Machine:
- Now allows variable to set dimmer fade time.
- Added feature to allow editing of expressions in Conditional Actions (see this post).
- Update driver class name for keyWe Z-Wave Lock so it installs properly.
- Let’s Get Started!
- Add virtual Lock when Lock Code Manager is installed.
- Prevent install of HSM and Mode Manager if these have already been installed.
- Show additional app descriptions properly on initial application load.
- Generic Zigbee Outlet, Send a power level of 0 event when device is turned off.
- Hampton Bay Zigbee Fan Controller
- Update
cycleSpeed() so it works like all the other fan controller drivers.
- Modify composite device creation patterns to prevent them from being orphaned when the parent Zigbee dni changes. (Note: If you are using the component devices, please click save preferences in the parent device, this will update the existing components.)
- Display message when update download fails.
- Scene 1.2: Fixed bug with Scene device setting for CT bulbs.
- Thermostat Scheduler: Fixed a bug where changes to settings sent from Rule Machine were not updating the thermostat, or being displayed in the UI.
- Maker API: Fixed a bug that caused an error for a decimal secondary parameter to a device command.
- Rule Machine:
- Fixed a bug where creating a connector would throw a null error.
- Fixed a bug where comparing two variables UI did not offer Done button.
- Fixed a bug where changing a variable comparison would result in a blank page.
- Yale Zigbee Lock: fixed battery reporting issues with models YRD256 TSDB
