¶ Drivers and Devices
- New drivers:
- Shelly WiFi Dimmer
- Shelly WiFi Switch
- Lutron VCRX (Visor Control Receiver)
- Leviton DZ6HD Z-Wave Dimmer
- Leviton VRCS1 Z-Wave Controller
- New driver features:
- Alfred Z-Wave Lock: now supports lock codes on DB1 and newer firmware firmware DB2 locks.
- Generic Z-Wave Button Controller: add doubleTapable support.
- Simple Lighting has been renamed to Simple Automation Rules
- Additional reciprocal action options added.
- Maker API: Add
evt.type for events (physical/digital)
- Rule 4.0:
- Made GV references faster in UI.
- Added
setScheduledSetpoints for Thermostat Scheduler actions.
- Button Controller has been unretired.
- Thermostat Scheduler:
- Added optional thermostat refresh interval.
- Added optional logging.
- Reworked user interface.
- Added external command to set thermostat to current scheduled setpoints.
- Sets only appropriate setpoint for heat or cool thermostat modes.
- Enforces required setpoint separation in user interface.
- Mode Lighting: Allow choice for non-physical on
- Dashboards now allow language localization for English, Spanish and Italian
- Rule 4.0:
- Fixed Cancel Rule Timers for Waits.
- FIxed 0 offset for Sunrise and Sunset.
- Fixed sorting of buttons for button devices with more than 9 buttons.
- Fixed Time of Day condition bug for button device trigger.
- Fixed display bug with time for Thermostat Scheduler actions.
- Fixed missing action: Stop dimmer fade.
- Rule Machine: Fixed attempt to clone a deleted rule.
- Honeywell T6 Pro Z-Wave Thermostat: fix operating state not updating.
- Zooz 4-in-1 Sensor: Format battery level as integer.
- Aeotec TriSensor: Format battery level as integer.
- Hubitat Safety Monitor: Fixed disarm after disarmAll issue.
- Lock Code Manager:
- Fixed static limit of 30 users, now reads code slots from each lock.
- Relaxed code retry timing to accommodate slower lock response times.
- Virtual Lock Driver: Fixed lock codes starting with 0 not working.
- Notifier:
- Fixed bug with Any Lock Code.
- Fixed UI selector for selecting Lock for Lock Codes.
- Fixed bugs with required setpoint separation.
- Fixed period sorting for 12 pm times.
- Changes to the overnight cleanup process to make it less processor-intensive.
- Overnight backup will happen immediately after the cleanup has finished.
- Added an additional option
parseWarning to UDP messages; if set to true any warning messages will be returned to the parse method or callback method instead of being sent to the live logs.
- Orphaned Zigbee devices (i.e., deleted but never excluded or factory reset) will now create a new device using the default “Driver” device when they first communicate with the hub.
