¶ Drivers and Devices
- New drivers:
- Nexia NX1000 Z-Wave Scene Controller
- Remotec ZXT600 Z-Wave IR AC Controller
- Sengled Button Controller (E1E-G7F)
- EVA LOGIK In-Wall Switch (ZW30)
- RGBgenie Button Controller (ZB-5001)
- Ring Alarm Keypad Gen1 (C7 required)
- Ring Alarm Keypad Gen2 (C7 required)
- Ring Alarm Motion Gen2 (C7 required)
- Ring Alarm Contact Gen2 (C7 required)
- Aeotec Door/Window Sensor 7 Series
- Aeotec Water Sensor 7 PRO
- Aeotec AerQ Temperature/Humidity Sensor
- RGBGenie Z-Wave Micro Switch (ZW4004)
- RGBGenie Z-Wave Remote (ZW5002)
- New compatible devices
- Sinope Smart Plug (SP2600ZB) using Generic Zigbee Outlet
- GE Zigbee Switch (43076) using GE Zigbee Switch
- GE Zigbee Dimmer (43090) using GE Zigbee Dimmer
- UK alertMe socket using Iris V1 Outlet
- MINOSTON In-Wall Smart Switch (MS10Z) using EVA LOGIK In-Wall Switch
- Sunricher (ZG2833K8_EU05) using RGBgenie Button Controller
- (existing RGBgenie 8 Button Controller driver is depreciated)
- Aeotec Door/Window Sensor 7 PRO using Aeotec Door/Window Sensor 7 Series
- Aeotec Door/Window Sensor 7 Basic using Aeotec Door/Window Sensor 7 Series
- Sunricher Z-Wave In-Wall Smart Switch (ZV9100) using RGBGenie Z-Wave Micro Switch
- Sunricher Z-Wave Dim Remote Control (ZV9001K12) using RGBGenie Z-Wave Remote
- New driver features
- Honeywell T6 Pro added PowerSource capability.
- Inovelli Multi-Color Bulb added support for firmware 2.30 and later.
- Aurora Zigbee Switch added power monitoring for double and single socket.
- Button Controllers
- Added cloning of Button Controllers.
- Allows multiple button devices per instance.
- Allows expanded ColorTemperature range of 1500 .. 9000.
- Supports volume adjustment, mute/unmute.
- Amazon Echo Skill
- Added support for thermostat devices.
- Added optional advanced thermostat interface.
- Add device not responding option (enable to mitigate persistent device not responding messages).
- Maker API
- Allows refresh of access token. Warning: Doing this invalidates all existing endpoints for this instance of Maker API.
- Allows hex RGB color for command setColor, in format, e.g.,
{“hex”:”15fe21”}
- Rule 4.0
- Allows pause/resume of Motion Lighting and Simple Automation Rules. For this to work you must first open Motion Lighting Apps and/or Simple Automation Rules and hit Done to populate lists for RM.
- Thermostat Scheduler
- Added Thermostat Fan Mode control.
- Scene 1.2
- Thermostat Scheduler: Fixed ecoMode.
- Rule 4.0:
- Now removes settings for devices in deleted actions.
- No longer displays triggers with remote devices.
- Fixed bug with Custom Attribute variable trigger.
- All drivers: prevent temperature offset from being reset when configure is called.
- EVA LOGIK Smart Plug Dimmer: fix reporting issues with new firmware.
- Yale Zigbee Lock: fix battery reports for YRL226 TS and YRD226 TSDB.
- Maker API: Fixed multiple CORS hosts.
- Mode Manager: Fixed earlier/later of two times.
- Fortrezz MIMO2+: Fixed reporting issues introduced in 2.2.1.
- Button Controllers: Fixed bug cloning Button Controller 3.0.
- Thermostat Scheduler: Fixed bug with thermostats that don't have supportedThermostatFanModes.
- Rule 4.0 performance improvments.
- Logging made optional in Simple Automation Rule.
- App events made optional in Rule 4.0, Motion Lighting and Simple Automation Rule.
- Added missing doubleTapable capability to sengled button controller driver.
- MakerAPI: Fixed CORS origin issue.
- Thermostat Scheduler: Subscribe to all thermostat setpoints.
- Added
ConcurrentHashMap
to the list of allowed classes.
- Groovy version updated from 2.4.10 to 2.4.19.
- MQTT Client allows setting clean session flag (defaults to true).
- MQTT Client now supports TLS with client certificates.
