¶ Drivers and Devices
- New drivers:
- Fibaro Smart Implant
- HomeSeer Fan Controller FC200+
- Inovelli Fan/Light Switch LZW-36
- Inovelli 4-in-1 Sensor
- Ring Alarm Hardwired Retrofit Kit (C-7 required)
- Generic Component Drivers
- Generic Component Fan Control
- Generic Component Humidity Sensor
- Generic Component Voltage Sensor
- New compatible devices
- EVA LOGIK Outdoor Plug (ZW96) using EVA LOGIK Smart Plug
- Samotech MS104Z using Generic Zigbee Switch
- Heiman Z-Wave smoke detector using Generic Z-Wave smoke detector.
- New driver features
- Inovelli Multi-White Bulb (LZW-41): Performance updates when using firmware version 2.27+.
- Added firmware version report to Alfred Lock driver
- Amazon Echo Skill App
- Added support for garage door controllers.
- Added support for fan controllers.
- Added support for shade controllers..
- Rule-4.0: Allows selection of format for
%time% and %now% (one option per rule).
- Fixed a bug in the Aeotec water sensor 6 driver that was preventing saving of configurations when the device was on battery.
- Fixed multiple drivers incorrect formatting of firmware version numbers.
- Button Controller 3.1: Fixed bug with Adjust Dimmer
- Generic Z-Wave Smoke/CO Detector: Change event value from test to tested.
- Zooz Double Switch: Remove extra logging.
- Rule-4.0: Fixed multiple device trigger bug.
- August Pro Lock: Add C7/S2 support.
- Fixed multiple driver compatibility issues with S2/S0.
- Leviton VRSC4 Z-Wave Controller: Fix Null error with child dimmers on startup
- Fix
groovy.lang.MissingMethodException for SupervisionGet on Zooz drivers.
- C-7: Fixed Z-Wave repair behavior with sleepy devices.
- C-7: Fixed Z-Wave inclusion issues.
- C-7: Fixed occasional repair lock-up.
- Performance and stability enhancements.
- C-7: Added update mechanism for Z-Wave radio firmware.
- C-7: Updated Z-Wave settings page to include node routes / speed and highest security grant.
- Add universal Z-Wave security encapsulation commands, automatically detects correct security encapsulation requirements of none, S0, S2_UNAUTHENTICATED, S2_AUTHENTICATED or S2_ACCESS_CONTROL (example).
- Signatures:
String zwaveSecureEncap(String cmd)
String zwaveSecureEncap(hubitat.zwave.Command cmd)
- Change Zigbee
EZSP_CONFIG_PAN_ID_CONFLICT_REPORT_THRESHOLD from 1 to 10
C-7 hubs are receiving major Z-Wave updates with this release and require some user intervention to complete the process.
Part 1 of the update will happen automatically during startup. There may be an automatic reboot during first startup on 2.2.3.
Part 2 requires user intervention. Under Settings > Z-Wave Details you will see a new button "Firmware Update." This will start the radio firmware update.
Please note that the firmware update takes roughly 10 minutes to complete; please let this process complete fully before attempting to do anything. If you run into trouble please reach out on the community; we will be watching for people posting problems.
Once this is complete it is recommend going through and removing any failed nodes from previous inclusion issues.
