Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and 1-2 minutes to perform the update after you select Update Hub. We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
¶ Drivers and Devices
- Centralite Zigbee Dimmer (spectrum) Spectrum edition HA Dimmer Switch 3385001-ZHA
- Lutron fan control driver (no level commands)
- Aeotec Panic Button (DSA38)
- Zooz Zen51 Dry Contact Relay
- Zooz Zen52 Double Relay
- Zooz 4-in-1 Sensor New
- Heatit Z-Water
- Heatit ZM Single Relay
- Heatit ZM Thermostat
- LIFX 4-Gang Switch
- Lutron Shade (no level or switch commands)
- Monoprice 6 Zone Audio Controller
- Generic Component Audio Zone
- Global Connect Relay Module [Global Cache GCRL3A]
- Generic Component Sound Sensor
- Generic Component Presence Sensor
- Global Connect IR Module [Global Cache GCIR3]
- Inovelli Z-Wave Red Scene Dimmer (replacement of "Inovelli Z-Wave Smart Scene Dimmer S2")
- Ikea ASKVADER Outlet strip using Ikea TRADFRI control outlet
- Ring Outdoor Contact Sensor using Ring Alarm Contact Sensor G2 driver
- Candeo rotary dimmer using Generic Zigbee Dimmer
- KAIPULE Ceiling-Mounted Motion Sensor using BeSense Motion Sensor driver
- Tuya, Blitzwolf and Third Reality water sensors using Generic Zigbee Moisture Sensor (no temp)
- Visonic Glass Break Detector using Generic Zigbee Glass Break Sensor
- ESTTECH EST-LED-GH001 grow light using Advanced Zigbee Bulb
- Add double Tapped event to Lutron Pico Driver
- Centralite Keypad, enable motion events
- Add position change commands to Generic Z-Wave Shade driver
- Add turn on transition time preference to Caseta/RA2 Lutron Dimmer driver
- Add option to disable battery reporting for line powered Zigbee valves
- Added missing battery capability for Generic Z-Wave Shade driver.
- Add
ChangeLevel capability to Nanoleaf Aurora driver
- Added
ChangeLevel capability to LIFX Color, LIFX CT, LIFX White, LIFX Color Legacy drivers
- Pushover: Added preference option for Emergency
- Rule 5.1: Added "sticky" triggers, to trigger when a device state persists for selected period, and several other new features (see this post).
- Rule Machine: Added ability to import a Basic Rule or Simple Automation Rule to create new equivalent Rule 5.1 (see this post).
- Scene-1.2: Added option to pre-capture Scene devices before Scene activation, and restore when activator device turned off.
- Hubitat® Safety Monitor/HSM Custom Rule:
- Added option to turn off switches upon alert
- Added support for gas detectors
- Thermostat Controller: Added option to use thermostat mode:off to induce idle operating state in controlled thermostat, as alternative to changing the setpoint.
- Basic Rule:
- Added set thermostat mode and thermostat fan mode
- Added Control Music Player
- Added Control Hubitat® Safety Monitor
- Added option to allow a restricted rule to continue to run when restriction occurs after the rule has been triggered (see this post).
- Simple Automation Rule: Added option to allow a restricted rule to continue to run when restriction occurs after the rule has been triggered (see this post).
- Motion Lighting: added option to use contact sensors in addition to motion sensors to trigger.
- COLOR picker added to all apps that allow color selection.
- Scene In-Use-By now visible on device page for Scene Activator device, for Motion Lighting, Rule 5.1, and Scene Transition.
- All apps with time inputs now have Erase Time button to remove a time setting; was missing for mobile browsers, now easier for desktop.
- Rule 5.1 has some new trigger optimizations. To take advantage of these, open your Rule 5.1 rules and hit Done.
- Thermostat Controller: Fixed startup "null Controller" bug.
- Motion Lighting:
- Fixed bug with 'Do turn on all even if any already on'.
- Fixed bugs with options involving multiple contact sensors.
- Rule 5.1/Button Rule 5.1:
- Fixed Set Color Temperature per Mode bugs with level and fade.
- Fixed mistaken options for Simple Conditional Action (Repeat While Expression and Wait for Expression).
- Fixed missing date option for Certain Time sunset/sunrise.
- Fixed bug with selecting Wait for Event after Wait for Expression.
- Fixed bug that prevents using a string variable for a local file name.
- Fixed bug setting Thermostat Scheduler mode based temperatures.
- Fixed bug setting multiple DateTime variables.
- Fixed bug with close valve.
- Fixed a bug with timeout on Wait for Expression, where the timeout threw an error.
- Fixed not setting In Use By correctly for variables used in
%variable-name%.
- Fixed paste of Simple Conditional action.
- Fixed issue of Set Private Boolean for
**This Rule** for clone and copy/paste to another rule.
- Fixed bug with relative-to-device comparison in trigger.
- All fan control drivers: Populate missing supported fan speed event.
- Mirror, Lock Mirror: Fix failed lock notification including all locks rather than just the failed lock.
- Pioneer AVR driver: Fix reversed mute status event.
- Fixed issue with apostrophe in app name for export.
- Fixed issue with Ignore Off option in Scene, if changed back.
- Fixed LIFX
SetExtendedColorZones command.
- Fixed switch reporting not working for Sinope switch and dimmer drivers.
- Zooz Zen77,Zen74,Zen72 handle basic report.
- Fixed bugs in Thermostat Scheduler with setting mode temperatures or variable times from RM.
- Lutron Thermostat driver: Fixed bug with
setHeatingSetpoint where it threw an error.
- Generic ZigBee Lock, fix duplicate events for Kwikset locks.
- Fixed configuration input error on Zooz ZSE44
- Nanoleaf Aurora driver:
- Fix duplicate text in description text
- Prevent
setLevel 0 event
- RGBgenie Controller ZB-3009/10, add missing
numberOfButtons event.
- Fixed Turn on Indicator configuration on Leviton DZ6HD Z-Wave Dimmer driver.
- C7: Optional Z-Wave firmware update to 7.17.1.
- New getting started workflow.
- Logs page shows pending hub actions, and apps/drivers generating excessive hub actions are marked in the logs.
- New Setting option allows swapping one device for another.
- Groovy version updated from 2.4.19 to 2.4.21.
- Added
/hub/advanced/databaseAlertThreshold and /hub/advanced/databaseAlertThreshold/123 endpoint to view and update database size alert threshold, respectively.
- Hub's IP address is no longer permanently cached in the UI.
- All app/device searches are now case insensitive.
- Better rendering of Log page tabs on smaller devices.
- Updated confirmation dialog on database restore.
- New color pick up for
setColor on device page.
- Minor IFTTT update for future service update.
- Added
roomName to DeviceWrapper.
- Long app labels are trimmed instead of throwing an exception.
- Enables multiple destinations for
HubAction with type LAN_TYPE_UDPCLIENT.
- Reduced default state and event history size to 11 entries and max event/state age to 31 days.
- Reduced Hub Mesh reconnect interval (when no other hubs are detected) from 5 minutes to 2 minutes.
