Easy Dashboard is a new easy-to-use and easy-to-create grid-based tile solution for viewing and controlling devices and other features on Hubitat Elevation. With Easy Dashboard, you can:
What's the difference between Hubitat Dashboard and Easy Dashboard? Hubitat® Dashboard is a older Dashboard that is incredibly customizable (e.g., supports custom CSS) but that most users would say requires more work to set up. Easy Dashboard is our newest attempt to make it simple to create beautiful, easy-to-use dashboards. Which you choose is up to you, and there is no reason to switch from Hubitat Dashboard if you are already using it – it will continue to work. If you are not sure where to start, we suggest Easy Dashboard.
Access to any Easy Dashboard available locally or remotely via either local or remote/cloud URLs you can open in your favorite browser or the Hubitat Elevation mobile app.
From the sidebar of your hub, select Dashboards.
In the top right, select + Add Dashboard.
If prompted, select Easy Dashboard. (Some users may have two options, Easy Dashboard and Hubitat Dashboard. If you do not see any options, an Easy Dashboard will be created by default.)
When prompted, provide name for this dashboard and select devices or other options to include on this dashboard.
Select Create Dashboard to finish (if you do not see this button, make sure you provided a name for the dashboard).
To view or edit this dashboard in the future, select it in the list of dashboards (under Dashboards).
To edit devices authorized for a specific dashboard or to enable or disable editing while viewing or other specific options on a particular dashboard:
Navigate to Dashboards and find the desired dashboard in the list.
If you do not see the edit and delete icons next to the dashboard, select the gear icon in the top right toggle edit mode on.
Select the edit icon next to the dashboard to add or remove devices, enable or disable layout editing while viewing the dashboard, and other options.
