The Ecobee Integration app allows you to control your Ecobee 3 or later smart thermostat from Hubitat Dashboard or use the thermostat measurements and presence detection to create automations with Rule Machine®.
NOTE: Many Ecobee models are also compatible with Apple HomeKit (consult HomeKit documentation from Ecobee for more). On hubs that support the HomeKit Controller integration, pairing the thermostat that way offers an alternative with local connectivity, although either method can work, according to your preferences.
To get started, you'll first need to register your thermostat with the Ecobee app or web portal before you can add it the Hubitat Ecobee Integration app.
From the sidebar of your hub, navigate to Integrations and select Add Integration or Add Built-In Integration:
Choose the Ecobee Integration from the list of Hubitat Elevation Built-In Apps
Login to the Ecobee Integration app with the same credentials you use for your thermostat.
Confirm your Ecobee 3 or later thermostat(s) and any available remote sensors appear in the Ecobee Integration app preferences
Once your thermostat has been added to your hub, you can begin using it in your automations or access it directly from its device detail page on your hub, from Hubitat Dashboard or the mobile app, or other methods.
Available Rule Machine actions include:
Other commands may be available via Rule Machine Custom Actions.
Note: Hubitat Elevation thermostat drivers may show certain options that do not apply to all thermostats.
