Managing your Z-Wave network properly is important to maintaining a solid Z-Wave mesh network. Some of that management can be done here on the Z-Wave Details page. Be sure to read the How to Build a Solid Z-Wave Mesh document for tips on building a robust and resilient Z-Wave network.
This page offers an advanced view of details about your Z-Wave network and Z-Wave devices. It may be useful for troubleshooting; however, most users will not routinely need to use this page. For example, to add a Z-Wave device to your hub, use the Add Device page.
This document describes the Z-Wave Details page on hub models C-7 and newer. Models C-5 and older offer fewer options (e.g., no region selection) and a different device table with less information and no actions, although it can still be useful for setting basic information about all Z-Wave devices on your hub.
The features available on this page are described below:
At the top of the page, you will see Z-Wave is enabled (as pictured in A above) or Z-Wave is disabled. If enabled, the remaining options and information will appear.
Below this status is a row of buttons (labeled B above):
Add Device: takes you to the Add Device page (you can go there yourself to add any device, including Z-Wave devices).
Disable or Enable: can be used to turn on or off Z-Wave functionality on the hub.
The View Logs: allows you to view live logs for routing, signal and channel information. On legacy Z-Wave, this shows only Z-Wave packets sent from hub. On models using Z-Wave JS, more traffic is displayed. In all cases, regular Logs will be more helpful for general device troubleshooting.
Model C-8 Pro users may also see options here to Switch to Z-Wave JS or Switch to legacy Z-Wave. New model C-8 Pro setups will use Z-Wave JS, but existing users can switch if they want. If you switch to Z-Wave JS, you should understand that:
On a new hub (i.e., with no Z-Wave devices), most of the above points are not applicable. Switching before including any Z-Wave devices is easy, and you may consider trying if you enjoy testing new features.
Below this row, you will also see Firmware version (Z-Wave radio chip firmware version) and ZWave-JS version (software version of Z-Wave JS hub is using internally) if using Z-Wave JS. These data points are labeled C above.
The Settings section (D) offers one to two options:
Select the Update settings button (E) to save the updated values if you change either setting.
The Maintenance section (F) offers several features:
NOTE: You may also perform a general Z-Wave exclusion from Devices > Add Device > Z-Wave > Start Z-Wave Exclusion — a handier spot than it may sound given exclusion is a good step to try before trying to include a device. See the Add Device page documentation for more.
NOTE: Running a Z-Wave Repair or "rebuild network" will not revive failed devices. Z- Wave repair is very network intensive since the hub will attempt to ping and possibly re-route every device (except sleeping nodes).
View device graph: View a visual representation of your hub (Z-Wave controller), repeaters, and non-repeater nodes and routes.
View device topology: View a map of your Z-Wave network, showing which devices connect through which repeaters and/or directly to the hub.
Device firmware updater: Provides method to update firmware on Z-Wave devices you have included to your hub's Z-Wave network. Use Manage firmware files inside the updater utility to add Z-Wave OTA update files (or Z-Wave JS users can use Automatic firmware discovery after selecting a device to check for files from the Z-Wave JS database), then select the device, target, and firmware file, and select Start update. Battery-powered devices may need to be manually waked before starting the update and the device on your hub temporarily disabled or switched to the "Device" driver to prevent the driver from putting them to sleep when an update is in progress.
Firmware update: Appears if optional hub Z-Wave radio firmware update is available. This button will be visible only if such an update is available. (This option refers to the hub's built-in Z-Wave radio, not device firmware.)
Refresh statistics: Updates data for the Stats column (J) in the device table. On recent platform versions, this data is not updated automatically unless using Z-Wave JS (i.e., not legacy Z-Wave).
Antenna test: A diagnostic tool that can be used to diagnose whether the Z-Wave antenna is working properly (typically used only with the guidance of support). To use, select Antenna test, then, when prompted, choose a Z-Wave device to test against and select Start test. The test will run to test RSSI with the antenna connected. Then, disconnect the antenna and select Continue to perform the second half of the test. (The Z-Wave antenna is the one closest to the USB-C port.) When finished, reconnect the antenna. RSSI will generally be notably different between the two tests if the antenna is functioning normally.
SmartStart list: Provides a way to manage Z-Wave Smart Start devices on your hub, either removing them from this list or adding via QR code or manual input.
The Z-Wave Radio Devices table (G) shows a list of your Z-Wave devices with information about them. Older hubs or hubs not running Z-Wave JS will show less information. Columns displayed include:
zwave.getStoredValues() to retrieve)
