In this document, you will:
Let's start by learning how to add a device!
To add a device, first make sure your device is compatible:
The hub is compatible with most standard Zigbee, Z-Wave, and Matter devices, as well as a variety of LAN and cloud devices. (Note that a device is not compatible simply because it says it is "smart"; the manufacturer must follow standards or provide an open interface for integration that the hub can use. If you have a favorite device that isn't compatible, we suggest providing this feedback to the device manufacturer.)
The list above contains devices that are known to work with built-in drivers. However, many more standard devices should work with built-in drivers, and third-party apps and drivers allow you to integrate an even wider variety of devices that we have not tested.
Follow the instructions in this video to add a device to your Hubitat Elevation hub using the mobile app:
Alternatively, follow the instructions in this document to add a device using either the hub interface or the mobile app:
If you have trouble adding devices, see the notes at: How to Troubleshoot Your Hub.
For additional tips on adding devices or using your hub, see:
